Augustus 07, 2026, 07:43:05 *
Auteur Topic: Jonckheere Bermuda wheel variation  (gelezen 12253 keer)
Tyrolese
« Gepost op: Augustus 03, 2016, 10:33:36 »
So far, i have only seen the Efsi standard wheels, as seen on the Sabena model, on the Jonckheere bus.
Now i have this one with disc wheels. These type of wheels i have never seen before on a Efsi model (which does not mean anything, as there are still so many things, i haven´t seen before, when it comes to die cast  icon_biggrin)
So were the disc wheels some sort of short run wheel types, perhaps used on early examples?
« Laatste verandering: Augustus 03, 2016, 10:35:18 door Tyrolese » Gelogd
« Antwoord #1 Gepost op: Augustus 04, 2016, 09:16:50 »
The disc wheels are seen on later Efsi models, just before the name-change to Holland Oto, if I'm not mistaken.
« Antwoord #2 Gepost op: Augustus 04, 2016, 10:13:11 »
There are 3 other wheel-variations beside the two you showed:
The "Airport" has the last used wheels.
« Laatste verandering: Augustus 04, 2016, 10:15:02 door demi10 » Gelogd
Tyrolese
« Antwoord #3 Gepost op: Augustus 06, 2016, 06:02:27 »
Great info. I knew about the all black wheels on Land Rovers but not on the bus.
The dot wheels i have also never seen before since I don“t find Efsi models too often here.
« Antwoord #4 Gepost op: Augustus 06, 2016, 09:11:12 »
Also, the Bermuda bus has four different front ends; one with the Mercedes-star, one reading Scania, one reading Volvo and one reading DAF
« Laatste verandering: Augustus 06, 2016, 09:12:44 door buttonfreak » Gelogd
« Antwoord #5 Gepost op: Augustus 07, 2016, 07:57:06 »
« Antwoord #6 Gepost op: Augustus 28, 2016, 05:35:17 »
hebbe hebbe,,,, wav
